Latest from Quality Control
Forging Buyers 2122 Promo
Home
New Article
April 26, 2022
Exact Metrology
Np Artec3 D Scanner
Pongchart Buranaprasertsuk | Dreamstime
Dreamstime 197374349
InfraTec GmbH
Np Infratec Imageir 8300 800
Dovzhykov | Dreamstime
Dreamstime154075769 800
Columbia Marking Tools
Np Forg Cmt Mite E Mark 800
The Adcole Model 1100 gauge.
Crankshaft, Camshaft, Piston Gauge
Nov. 9, 2012
Complete system uses dual-linear gratings Measures 3,600 data points per revolution of cylindrical parts
An ADCOLE CORP. gauge provides submicron accuracy with fast, unattended cycle times, for manufacturing and quality control of critical rotating components. The Model 1100 gauge is a complete system that uses dual-linear gratings for measuring 3,600 data points per revolution of cylindrical parts with submicron accuracy.  Easy to load/unload and operate, measured parameters for crankshafts include diameter, roundness, cylindricity, straightness, parallelism, taper, radial runout, concentricity, axial runout, index angle, throw, true position, lobing, center deviation, lengths and widths.
Well suited to help engine and driveline component manufacturers maintain the close tolerances required for optimal fuel economy and engine life, the Adcole Model 1100 gauge measures main and rod journals with ±0.5 micron radial accuracy, 0.5 micron linear scan accuracy, ±0.001 degree angular accuracy, ±5 micron axial accuracy, and 10% of tolerance repeatability.  It has dual PC CPUs linked via DCOM, Windows 7-based software, and a 19-in. color touch screen monitor.
Visit www.adcole.com
