The ADCOLE CORP. Model 1304 multi-headed camshaft gauge is an updated design that allows fast changeovers between parts of different length parts, and lets operators load and inspect articles quickly. It achieves parts inspection with one-minute cycle times, measures 3,600 data points per revolution, and can be loaded automatically by gantry or manually. Featuring four programmable moving heads and a tailstock with 6-in. travel, this gauge allows parts access from a touch screen, handles different length parts, and each of the heads can move to a park position for easy access.
Incorporating an accurate headstock spindle with high-resolution glass scale angle encoder systems, the Adcole Model 1304 permits on- or off-line programming. Menu-driven, it has dual Windows 7 computers and can measure 20 different parameters including roundness (LSC, MIC, MZC), diameter (LSC, 2-point), profile, taper, crown, timing angle, velocity, acceleration, runout, and concentricity.
Visit www.adcole.com
